Results 1 to 7 of 7
Thread: View new posts
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    View new posts
    When I click on View New posts is gives me this "New Posts (since December 31st, 1969, 6:00 pm)" I was hoping for something newer than 1969. Maybe like since last visit. Is there something I need to set to change it from 1969. (Images of a DeLorean are popping in my mind right now)
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: View new posts
    Quote Originally Posted by AV8TOR
    Does it show the correct post time for your post above? If so, try clearing your cookies and see if that helps. Also, what browser are you using? I'm running the Db repair function on my end to cover the bases.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: View new posts
    Yes it does (PostPosted: December 7th, 2008, 8:39 am)
    I am using FireFox 3.0.4
    Polaris 280 robot
    Pool Calc user
    SeanB's Avatar
    Mar 2007
    2,622
    Re: View new posts
    I didn't find any errors on this end and I'm using FF as well. Did you try clearing your cookies?
    TFP Founder
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: View new posts
    Yes sorry, I deleted 3 cookies from TFP - shut down the browser - re logged back in and the same 1969 date when view new posts. No problem selecting view your posts nor view active topics.
    Polaris 280 robot
    Pool Calc user
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: View new posts
    What time does it say your last visit was (upper left hand under the "become a tfp supporter" icon ) ? Sometimes mine won't update unless I've been off the boards for a few hours.
    Luv& Luk
    -Ted
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: View new posts
    Quote Originally Posted by waste
    Its says Last visit was: December 7th, 2008, 11:13 am - don't know what it was before because I did not look but maybe I did wait long enough to check it because it is correct now. Thanks for your help.
    Polaris 280 robot
    Pool Calc user
