Thread: Fiber glass issues on spa
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    373
    Hey guys...
    I have a spill over spa made out of fiberglass. It is completely paved around it with bullnose at the top, but the very top does show before the pavers lay against it. Its about 4 inches of fiber glass.
    Anyway, I was given this spa by someone that is redoing their yard and although it is in excellent condition, there are the tinyiest hair line cracks (really more like scratches) in the fiber glass. I think pool steps sometimes get the same things.
    I dont think these scratches / cracks are in danger of causing problems, but I want to know if there is a way to fix them up so it looks brand new, or at the very least treat the fiber glass so they don't spread and new ones aren't created.
    Thanks a million in advance.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Fiber glass issues on spa
    Is the crack in fiberglass or is there an acrylic shell on top? If the cracking is in the acrylic, you can drill a VERY small hole on either end of it to stop it from spreading. I'm talking like 1/16" deep.
    The only reason to 'patch' it would be if it was losing water, and usually that's not an issue. The patches tend to look worse than the cracking itself so as long as you can stop it from getting worse, I'd let it be.
    Is it getting any worse?
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    373
    Thanks.
    It definitely wouldnt lose water because of it. These arent inside the hottub. Just on the very top lip. Very superficial.
    I don't know if it is getting worse or not. Ive only had it for about a month of this summer and now its all covered up.
    I have to assume ther is some type of acrylic shell on there. It is the typical white shell on spas...
    It isnt terrible at all. I just wanted to know if there is anything I could do to make it look new again. thanks again for your help!!!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Ok. Maybe you can try some wax/polish products? I'm sure Billy Mays sells something that would do the trick. Let us know if you find something!
