Reviving this old thread again....
I've got a Pentair Amerilite incandescent fixture which is totally shot (leaking). The seal where the cord enters the fixture is cracked and the metal housing itself has pinholes. I want to switch to a color LED and I don't want to replace the lens/housing and put an LED bulb in, I want to replace the whole assembly with a self-contained led lens/bulb assembly that is compatible with the existing cove. This seems like a better way to go as the LED fixture itself will be in-contact with the water which should give excellent cooling and I would expect this to greatly extend the life of the light. Also, the sealing system of the "normal" fixtures with the clamp wire makes me uneasy. It looks like the choices are:
J & J ColorSplash XG
Pentair Intellibrite COLOR
I'm not sure if there are others to consider. The diffuser on the Pentair seems to be a better design, but it really irritates me that Pentair voids your warranty for a self-install, I'm not sure if J&J does this as-well, I'm still researching. Anyone have experience/recommendations? Thanks, c
