Yesterday, both skimmers were working normally. Today, only one is working. If I plug the working one, then the other suctions - but not both of them at the same time. Any suggestions?
Thank you!
Thank you!
Most likely culprit is the gasket under the pump strainer lid.I did a very thorough cleaning of the filter and it seemed like I was getting somewhere. I noticed that the pump was filling up with more water like it used to. But then, after a short while, I can see water flowing into the pump, but it is not full.
(My pressure gauge is not working and I will replace it soon).
I don't no where I could possibly have an air leak. There is absolutely no water leaking anywhere from my plumbing.
No. After the pump is the pressure side. Water leaks out, air won't leak in.Hey Richard - I have my suction side issues resolved - thanks to your advice. I have some air still coming out of the returns. I have a few drips on some lines coming out of the pump and going into the filter. Is just a few drips enough to get air in the return lines?
