Is there a minimum pressure required for a DE filter?
I am running very low pressure with my Quad DE100. The filter gauge usually reads 0 - 3 psi. I know water is flowing because I see the check valve open and the flow meter indicating 35 to 45 gpm. However, is this a problem for the filter? I checked the manual but only a max pressure is provided (50psi), no minimum.
thanks,
carlos
thanks,
carlos
