First full year with the pool. Construction just finished last fall on the pool. Legacy pool here which is similar to splash pools. Liner never needs replaced so deck can be built right over pool edges. I really took advantage of it. Father-in-law helped build custom bench with storage you can see in pics below and now we have two matching gates. I installed fence and did some work on the railings. Had carpenter do deck supports and deck flooring. I also did lighting which you can see on step up in deck and steps. All pool equipment is hidden in a door on left side of the stairs.
