You'll need the pump on at least half an hour to mix the water well before you start testing.
You need to run all of them. Scratch that - you can be reasonably sure you have no chlorine, so save the reagent. But run everything else. If it turns out you have astronomical CH or CYA, you'll need to replace some water first. And you won't be able to test pH once you start, so you need to fix that first, and you'll need to know TA to fix pH.
There's no way to know. Initially, if you can check and add bleach every hour, you'll make rapid progress. You'll see as time goes on that you need to add less and less each time, and when you notice that, you can start to stretch out the intervals a little, in case you have a life beyond the pool. But the more often you maintain the FC level, the faster it will go. I think the record to turn a green pool clear is three days, but that guy got up every two hours all night long all weekend to do it. Most people require a week or ten days. Worst case was about a month. A lot depends on how diligent you are about maintaining the FC and brushing and vacuuming.
Post some pictures so we can follow the progress.
