pHin monitors your pH, ORP and Temperature 24x7. We also scan test strips once a month to monitor your TA, TH, and CYA. The test strips are not very accurate, but they are able to provide a high level directionally accurate reading that is helpful, especially for those three levels that don’t change very frequently.
Many people have concerns over the quality of their water ("is it safe for their kids" for example), and appreciate the confidence that pHin can provide, as well as the simple and clear instructions to help them keep their water balanced. If you’re already comfortable with pool chemistry, and have a system that works well for you, you may have no need for pHin.
Our lead investor is Lonza, the worlds leading manufacturer of pool chemicals, they make brands such as Poolife, GLB, Ultima, Leisure Time, etc. In addition to our own testing, Lonza has also conducted testing of our monitor, and our recommendations. The specific sensor probes we use are manufactured by Sensorex, a leading US sensor manufacturer who makes similar probes for commercial pools.
Be aware that pHin is not a meter. To achieve our goal of simplicity and ease of use, we leverage averaging and trending of data to know when to alert customers to add chemicals. So the readings that pHin provides at any given time will probably not match the readings you receive from a given spot check (although they will be in the ballpark).
