Hello I am currently making a portable vacuum for my above ground pool. I have the pump and filter installed just need an idea of how to attach the vacuum hose to the pump and filter. Thank you fir the help [emoji2]
The inlet is easy. A bathroom sink tailpiece will thread into a threaded coupling and is just right to friction-fit a vacuum hose on. Alternately, Lowes sells these hose adaptors out with the pool stuff.
I can't tell you how many times I've looked like a lost pup or someone meditating out in space at Lowes and had a associate ask if I need help only to (and I've got it hemmed down now) reply, "jimmy-rigging.." And it's like a code they all understand. That place should advertise has a health and balance facility as well as many times I visit the same two aisles 50x.
