Hello,
We have a new pool installed with a Compool automatic actuator. From what I understand it has 2 settings pool and spa. When in spa mode the return to the pool is completely shut off this is fine. However, when in pool mode the valve stops and looks like it returns 60-70% to the spa (for spillway effect) and 30-40% to the pool.
Is there a way to manually move the valve if I wanted to return 100% to the pool? I was thinking it would be more efficient in cases where we wanted to heat the pool. Also, our SWG is plumbed on the pool return after the valve. Right now it appears there is enough flow as the systems is generating chlorine, but I was concerned with summer approaching.
Thanks, Jim
Thanks, Jim
