Thread: Closing Pool - Fittings for Returns
    I do not want to lower our water level below the returns, but want to insure that no water enters back into the lines. Does anyone have any experience with either of these two products or comments? Thx.
    #1
    One Way Winter Pool Valve
    http://www.intheswim.com/Pool-Opening-a ... e/#reviews
    #2
    The Winter Duck Plug
    http://www.leaktools.com/products/winte ... %20new.pdf
    #3
    Typical Winter Plugs
    http://www.intheswim.com/Pool-Opening-a ... -Plug-I-G/
    18x36 IG Vinyl Grecian Lazy L (20k gallons) ~ Whisperflo DS 2.0HP pump ~ QuadDE100 filter ~ Autopilot SWG DIG-60 ~ (7) 4x16 solar panels
    Jul 2008
    Pittsburgh, PA
    118
    Re: Closing Pool - Fittings for Returns
    The third item is just a standard plug and I use those on all my closings without draining the water below returns. Use a powerful shop vac to blow through your return line and have someone else plug it while it is blowing. Then add antifreeze to the lines. With the frequence I do it we usually dont get wet, but you might want to be prepared for that. If you have multiple returns on one line, plug them from nearest to equipment to farthest, or the ones that blow the hardest first. Work in a series without letting up. I have never used the duck plugs but other companies in my area do. They most likely work, just make sure to put the secondary cap on quickly after blowing, and still add antifreeze.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Jul 2008
    Pittsburgh, PA
    118
    oh or you could make up a fitting with a male adaptor, 90, female adaptor, and plug in order to "pipe" your return above water level. Just make sure you get a good seal on it, use teflon tape and silicone lube, thick stuff. This way you can blow out the lines by yourself and then add antifreeze from the pool side as well as equipment side. This is how I close pools that I do on the side. If you need more info on this message me and I will make one and take a picture for you.
    Matthew
    Pittsburgh, PA
