God morning, mr gunite. I read chem geeks post and have been following yours. I am wondering if an intense little slam-style sequence of beating it down would oxidize whatever nefarious substance is in there.
I'm not suspecting organics alone or mine would be the same right now...though my useage is riding higher than normal with pollen/maple keys/spring shenanigans in a wooded area etc. (eg 3.5ish a day in ppm versus normal 2-ish in a pool I dose to 7).
When I had to knock down ammonia in the original swamp, I would literally dose every hour. Somehow, the chlorine has to win so it can get back to doing its job
Alternately, a partial water change might help dilute, but I'm guessing you're on well and perhaps prefer to fight he already sequestered water rather than dumping more metals in
Its Saturday...might be worth an "ammonia-style" every hour test/check/dose til you break its back. Worth a shot anyway. If nothing else, the response will give you good intel to work with.
Thank you for the helpful suggestions Swampwoman. Over the course of the past week, I've been checking FC levels ever 3 hours or so, which seems to have worked out ok for keeping FC above 12 ppm, although I did consider an hourly checkup at the beginning of the week when things were really bad. The FC consumption seems to have died down somewhat since last Saturday, so I'm keeping my fingers crossed that this downward trend continues.
The smell from the RV antifreeze is still strong though, so I'm thinking I may just 75% empty this pool and then refill maybe at least partially from a truckload of water to ease the strain on the well pump. The last thing I need this year is to have to replace the well pump on top of all the other nonsense I've had to shell out the dough for already. Thankfully, the temps are still cool here, so replacing that much water is pretty low risk I think for damaging the plaster, but I'm thinking I'll need to make this decision very soon, since it'll probably be warming up within the next couple of weeks.
Daily pool readings update:
Overnight FC drop - 1.5 ppm (up from 1 ppm Thurs/Fri night)
FC - 15 ppm
CC - 0
TC - 15 ppm
TA - 100
pH - 7.2 (taken last night at FC = 9)
CH - 225
CYA - 35
I only used 3 gallons of Clorox yesterday (down from 5 gallons on Thurs.)
Again, in comparison to the normal mid-July sunny summer day, I use between 0.5 to 1 gallon of Clorox per day.
I also dumped in about 7 lbs of baking soda last night which was suggested by various RV websites to kill the smell of the RV antifreeze. Doesn't seem to have done much in that regard. I'm guessing I would need a lot more than 7 lbs to have any real effect on killing that smell.
The only other noteworthy info I have is that my pool was immaculately clean at this morning's FC check. Both skimmer baskets were completely spotless, which I think is actually a first since I've owned this pool. Also the bottom of the deep had very, very minimal dirt and there was almost nothing floating on the surface of the water. This is a huge change from the large amount of tree buds I've been scooping out of the skimmers each morning. The filter pressure was barely registering above starting pressure, but I did a backwash anyway, and added new DE. The DE that came out of the backwash hose was still white, so oh well, waste of a backwash.
So my summation here is still that either there is an algae growth in this pool either in the pipes/equipment somewhere that is not visible, or the RV antifreeze is somehow rapidly consuming FC still, or a combination of both.
