I plan on getting a small above ground pool to practice rolling our whitewater kayaks and a way to teach our daughters in the more friendly confines of clear pool water instead of river or lake water. A friend of ours has an easy set and recommended it for us. I fully expect these to have a life of a few years and I think that is all we need it for.
I'm concerned about the durability of the easy set pool. Since the pool will be subject to getting hit with the paddle, both the walls and the bottom, would the frame pools be a better solution?
I also plan on getting the salt system since we will be putting our gear in the pool and chlorine is not good for it. Is the Intex one good?
Thank you
Thank you
