Hi,
I am a new pool and equipment owner and I am at a loss for the settings I should be using for my pump, heater, etc... I am hoping I could get some guidance
Pool:
Equipment:
Plumbing:
External electrical timer
Please consider my on/mid/off peak energy usage times:
According to the pump instructions, it starts in prime mode, then switches to speed V3 for x time and then to V1 until power is cycled.
I would like to know
Here is a picture of the equipment pad (the gas and electrical for the heater are not hooked up yet)
Pool:
- In-ground12x24, 8ft deep end, 4 ft shallow - approx 13k gallons
Equipment:
- Hayward Salt & Swin 3C
- Hayward Pro Series Hight Rate Sand Filter
- Hayward H200FD Heater
- Hayward Super Pump VS SP2600VSP
Plumbing:
- 1 1/2 inch
- Two lines, one from skimmer one from drain
- on peak (expensive) is 11am to 5pm
- off peak is 7 pm to 7 am
- mid is 7 am to 11am and 5pm to 7pm
- what start / end time to set the electrical timer to (how long total to pump for)
- what RPM to set the speeds to and for how long for the pump (considering heating needs, salt water system, etc)
- Other than setting the desired temperature for the heater, do I need to set anything else? Does it know to only heat when the pump (water flow) is running? I don't see anything in the instructions for timing - just temparature adjustment.
