Hi everyone,
What is the recommended method for spanning the skimmer throat when using 4" wide coping? I used to build pools, but we used deck-o-form or the old cast coping pieces that were larger.
I have seen references to a stainless steel skimmer bar - but I have never seen such a thing. Links would be great, or the proper terminology.
My problem is that I have a gunite pool with travertine coping. There is no expansion joint between coping and deck, so I am dealing with pieces popping off, and in some cases, pieces cracking due to the concrete deck expanding.
I have 2 choices in my mind pull the copping and slide it forward, or cut an expansion joint all the way around 1.5" deep. The skimmers were spanned with a large piece of ceramic tile, and the coping placed on that. It is solid, but will have to be destroyed to get the coping up. There must be a better way then this.
Thanks for any advice.
