Hi All,
I have 2x returns in the pool, and one in the spa. They appear to be PVC pipe that was cut roughly to where the finished pebble surface would be. The pebble is covering the outsides of the pipe, and comes around the front of the pipe a little in some places. They are 1" Schedule 40 PVC.
Both pool returns and the skimmer are in the deep end, and this is a kidney pool with the spa in the narrow part. I think it will be hard to get a good rotation of water flow going to make the skimmer work better, but I'd like to try.
I can only get access to the inner diameter of the pipe, without chipping away pebbletec. This means I would need to either:
A. try to find an eyeball that attaches to the inner diameter of a 1" pipe
B. Use a little length of 3/4" pipe and glue it into the inner diameter of the 1" pipe (i would need to sand it a bit), and then attach an eyeball to that.
Unfortunately, either of these will restrict the flow down to be more like a 3/4" pipe. I feel that 1" returns are already too small (and therefore too much flow restriction) for an efficient pumping system.
Or I could consider:
C. Try to get access to the OD of the pipe by removing some pebbletec around the pipe. I don't look forward to this.
I also don't see a way I'm going to be able to do this without draining the pool below the returns -- Considering I'm in California drought country, I suspect I'm going to have to wait until the fall rainy season to feel ok about wasting that much water.
Any great ideas?
Any great ideas?
