I know there have been lots of threads in the past on the pool rover jr. automatic cleaner but I thought I would add another to the pot. If you own an AGP and are looking for the easy way out on pool vacuuming, you need to get one of these. This thing is a breeze........
It does sometimes have to run over the same spot twice to completely clean the bottom, but still gets the job done in less than 2 hours(which is what it is set to run).
Emptying and cleaning the debris bag is fairly simple and the bag is machine washable. The only thing that is a minor pain is removing the vac. from the pool since its bigger than most vac.s that run off the pool filter.
All in all, I think its great for an AGP and works alot better than the lil shark that I was using as it cleans the bottom much faster and doesnt get stuck on the sides like the shark does, plus it doesn't suck debris into the filter so you might not have to backwash as much.
