G
Guest
Can a slab be used under an above ground pool?
I think it would be more stable, but probably a source of trapping moisture that could cause liner problems. Sloped with a center drainage system maybe? Of course you would need geotextile or foam lining between the liner and concrete slab.
Or is it best to place it on undisturbed soil so that it has plenty of drainage in case of leaking?
