Hi Everyone,
Need some help. Trying to rebalance my pool after using Jack's Magic #2. It says in the instructions that the FC reading will be skewed for up to 30 days, and to use the CC reading as your guide. I am measuring a CC of 6 and a FC of 1.5 after adding Clorox to help bring up the FC because it has been 3 weeks now with a FC reading of 0.5. Has anyone had this problem, or should I just wait the 30 days and see if it goes back the other way to a correct FC reading and a normal CC reading of 0 which is what I've had. I don't want to over chlorinate if in fact the readings are correct. I use the TF-100 test kit for my testing. Using a SWG. Thanks!
FC - 1.5
CC - 6
Alk - 70
PH - 7.6
Cal - 220
CYA - 60
FC - 1.5
CC - 6
Alk - 70
PH - 7.6
Cal - 220
CYA - 60
