My TA measures between 110 and 120. When the pool is being used much, the PH might sometimes raises 0.1 between daily testing. Do I need to do anything to attempt to lower TA? I'm tending to not do anything but am unsure.
If I need to lower TA, what is the best way to add the acid to lower the pH to 7.2 prior to aeration? I have an in-floor cleaning system for water return. Should I spread the liquid acid evenly along the length of the pool? you actually have one of the above issues before lowering your TA.
