Dear All,
I've just installed a salt water chlorine generator to my hot tub.
I'm also going to try the BBB system as well.
Can anyone tell me in what order I should address the various chemicals added to a freshly filled tub?
Should I add the CYA first, then add bleach to get a correct Chlorine level (which will then be stabilised), then look at pH, then TA, then borate levels and finally add the correct salt amount?
(How long a wait between adding / adjusting for each chemical?)
Or is there better order in which to address these variables?
D
D
