Outdoor Hot Tub
2000 gallons
Cartridge Filters
FC- 5
CC-1-1.5
CH-425
Alk-60
Ph- 7.3
CYA-35
Salt System CC-15(salt Cell)
System is run on a Pool Pilot Digital, Total Control w/ Acid Bath Feeder.
ORP set point is at 425. I have had to continual drop the set point due to high amounts of Chlorine being generated.
When Oxi-shock is added the ORPs jump to the 600 Range, otherwise they always hover around the set point.
When the ORPs hover around the set point, it turns on the salt generator, which then generates Chlorine and then the CL gets too high.
We had some very poor weather lately and I was able to slam it for 3 straight days with no bathers, and the CCs hardly moved.
I had a slight drop in CC but nothing significant.
Something in the water is dropping my ORPs, which is turning on the Generator whens it doesn't need to.
I have spoken with a tech from AquaCal, but he is not too familiar with this size body of water run on this type of system.
This one is a head scratcher. New water is the only thing that seems to drop the CCs. But it costs $$$ to heat that water back up.
Any thoughts would be helpful here, it's got me a bit stumped.
PF
2000 gallons
Cartridge Filters
FC- 5
CC-1-1.5
CH-425
Alk-60
Ph- 7.3
CYA-35
PF
