Thread: Replace DE filter grid or buy a new one?
    My pool is 15K g in-ground pool, I recently open the filter (Anthony VA) to clean because I got dust coming back into the pool. Turn out there are anout 3-4 grid got hole in it so I need to replace those. I have not clean the filter for a while, back wash I do it regularly. I'm thinking while I'm at it, just replace the whole set which will come out about ~$170, while the new filter is about $425 (Hayward Perflex EC65A DE Swimming Pool Filter). I need your advice, should I just replace the grid (the old filter is about > 6-8 years), or buy the whole new one. Another question is the EC65A is enough for my pool? Thanks.
    14,500 inground gunite
    7' connected spa with overflow waterfall
    Goldline salt water chlorine generator
    Hayward 4 cartridge filter
    Hayward 400K heater
    Completed January 07
    Mar 2008
    East Texas
    21
    Re: Replace DE filter grid or buy a new one?
    Is you filter housing cracked and faded? If so you may want to replace the whole thing. Those cracks eventually start leaking and there isn't anything you can do, except check your warranty. If I remember correctly Hayward has a pretty long warranty on the housing. If the housing is in good shape I'd just replace the panels. We went through the same thing with our previous pool, although I replaced the panels as they failed one or two at a time.
    ___________________________________
    42'x18' In-ground gunite diving pool with raised spa and waterfall.
    Hayward pumps, 400,000BTU propane heater, cartridge filter
    BBB
    Polaris 280 Cleaner
    The filter is in good shape; no crack. If I want to buy a new filter is the EC65 enough for my pool?
    Hayward 400K heater
