I've recently completed SLAMing my pool and I need to get my pool in balance. Here are my test results this morning.
FC 5.2
PH 8.0+ (My Taylor kit peaks at 8.0 but the water looked "pinker" than that)
TA 180
CH 300
CYA 50
First question, what order do I tackle this? I'm inclined to address CYA first so I can keep my FC level stable.
I need to add some muriatic acid to get the PH down. My thought is to add enough to get it down to 7.8 if it is indeed at 8.0 and retest and take it from there. I'm using PoolMath and it says to bring my PH down to 7.0-7.2 in order to address the TA issue.
Thanks for the help.
Also, a little forum etiquette advice. Is this the right forum or since I have a SWG should I have posted there?
FC 5.2
TA 180
CH 300
CYA 50
