Hi there,
Got my new TF-100 test kit and did my first test.
Here are the results:
FC: 26.5
CC: 1
pH: 7.4
Calcium: 375
TA: 130
CYA: 100
Obviously the CYA is way high from using pool store chemicals.
The FC is also way high. I used a full scoop of R-0870 but this was my first time testing so it could be operator error.
We don't want to drain the pool and add water to fix CYA. Is it possible to limp along with adjusted bleaching dosages for the rest of the season until the pool is drained for closing in the fall? After the winter we hopefully will have enough fresh water from rain, snow or spring fill to fix CYA.
The pool was sparkling a few days ago but is now cloudy. I can post a pic or give more details about what we've done this season but I don't want to add a bunch of info if it's not needed.
I've been reading the forum a lot over the last week. I've learned a lot (thanks!) but can only take in and retain so much at once. So you're help would be greatly appreciated! Where should I start?
Thanks so much
FC: 26.5
CC: 1
pH: 7.4
Calcium: 375
TA: 130
CYA: 100
Thanks so much
