I understand should add chlorine in the evening so works all night before daytime sunny burn off
lots of cloudy weather out here and is convenient to check pool in the AM before kids get in and add stuff if needed
so is chlorine burn off any different daytime cloudy from night time
i.e. should I change to evening schedule?
TFP search did not return anything
and
seems I add bleach, pH goes up, add acid; repeat
anything wrong with adding bleach & acid at the same time?
TFP search says from 2009 add one, wait a few minutes for it to mix, then add the other
still valid?
and
still valid?
