Hi
Am following TFP advice and pool is fine and pretty much matches PoolMath.
FC 5
CC 0
pH 7.6
TA 80
CH 250
CYA 30
But it soaks up chlorine and acid like a sponge. Am using 5.25% bleach from local hardware.
So set out to find stronger chlorine and found the HASA web site
<http://media.hasapool.com/productpages/P-1.pdf>
seems like an Ok company
where I see recommended
FC 1.5 to 3
CYA 60 to 80
the TFP chlorine/CYA chart shows at 60 CYA a min FC of 5
so am confused? how to explain the different recommendations?
Thank you
FC 5
CC 0
pH 7.6
TA 80
CH 250
CYA 30
FC 1.5 to 3
CYA 60 to 80
Thank you
