Hello to all.
My new 15'x3" easy set w/ solar heat(really works) and big intex pump is up and running!
The numbers(TF 100) for 7/20 are the tap water right after filling.
After taking second sample on 7/23, I added 8.7oz 6% chlorine to attain 3+ppm.
What do you think about the data? What should I change? 3PPm too low a target? Do I have to increase my CYA? I do not mind adding bleach each day. I'll take the pool down on Oct 1st.
Date 7/20
FC 9
CC 5
TC 14
pH 7.8
T/A 130
CH
CYA 0
Temp. 82
Gallons 2800
Date 7/23
FC 1.5
CC 1
TC 2.5
pH 7.7
T/A 100
CH
CYA 0
Temp 89
Gallons 2800
thank you for your input.
mothara
Date 7/20
FC 9
CC 5
TC 14
pH 7.8
T/A 130
CH
CYA 0
Temp. 82
Gallons 2800
Date 7/23
FC 1.5
CC 1
TC 2.5
pH 7.7
T/A 100
CH
CYA 0
Temp 89
Gallons 2800
mothara
