- May 28, 2013
- 360
- Vinyl
- Pentair Intellichlor IC-40
I noticed a in another posting, someone suggested diluting the water 50% when testing the CYA levels. Just so I understand, was this to get a more accurate reading? I am assuming because the lines are so close once you past the 60-level range that by diluting your water 50% and then takig the reading and doubling it will get you slightly more accurate reading. Is this the purpose of doing this?
