Results 1 to 11 of 11
Thread: Taylor Tech Bulletin for Storage of Reagents
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Back a couple of weeks ago, there was a thread started about storing testing reagents in a refrigerator. I gave it a big thumbs up, because I've been storing my reagents in the "beer" fridge in my garage since I bought the kit, and never had a problem. Of course, there were some dissenting opinions, so I decided to go to Taylor and ask them (if you want a clear drink of water, go to the head of the stream). Wellllll, it looks like I'm eating crow dumplings tonight. Taylor sent me the attached bulletin, and recommended that I not refrigerate my reagents, as the sudden change in temperature from the refrigerator to the outdoors causes the reagents to deteriorate.
    Hope this helps,
    Mike
    [attachment=0:3p478sem]Taylortechbulletin.pdf[/attachment:3p478sem]
    Attached Files Attached Files
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    ktdave's Avatar
    Katy, TX
    888
    Re: Taylor Tech Bulletin for Storage of Reagents
    Thanks for sharing that Mike! Very informative.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    You're more than welcome, kind sir!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    becky5687's Avatar
    Jul 2008
    SW Michigan
    26
    Wow! Being a newbie, I mistakenly bought my test kit at a local pool store (next kit will be the TF 100). They recommended I store it in the fridge to make it last longer... Thankfully I didn't, I just keep it in my pantry (a cool dark place like the pamphlet in my kit recommended). Maybe I should print this out and take it to the teenager who sold me my kit...
    15 X 30 oval AG ~ 12,000 gallons. (completed June 23, 2012)
    1 HP Cooper Ranger Sand Filter
    BBB Method / TF100 Test Kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    I just read the article and it's self contradictory. On the one hand they say to keep the reagents at an even temp 36 - 85 deg F and then say that the fridge will harm them - I think it may be a typo and they meant to say 'freezer' instead of fridge. Though it makes a lot of sense to not pull a bottle of reagent out of the fridge and then stick it in the blazing sun, it would seem that using the fridge then giving the bottle a couple hours to warm up inside would be acceptable before using the reagent poolside on a 90 deg day
    Just my $.02 - and what do I know? :P
    Luv& Luk
    -Ted
    Montreal Canada
    326
    Another tidbit of info, specifically on R-0004 is this, "All Taylor indicators are formulated to suppress interference from chlorine or bromine up to 10 ppm when the indicators are fresh. The amount of suppression decreases as the indicators age." - p 11, Pool & Spa Water Chemistry Guide, Taylor Technologies.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    One last item on the refrigeration issue, then I'll hush. Ever since I've stopped storing my reagents in the beer fridge and now store them in my house, my CYA readings have dropped by 20 ppm. Thinking that maybe my CYA reagent had gone south, I ordered a nice big fresh bottle last week, and it came in today. I tested my water this evening, and my reading is still down 20 ppm from when I was using refrigerated reagent. So, it appears that at least for the CYA test, refrigerating your reagent will lead you astray.
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by MikeInTN
    Remember when testing for CYA with the pool water cold, they always say to bring the pool water to room temp before testing. Guess that rule goes for the reagent, too?
    You're done SLAMing when:
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by Butterfly
    Evidently. At least it wasn't 40ppm off the other way, thank goodness!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I didn't know that! See, learn something new everyday.
    Yes, it coagulates in the fridge.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
