Results 1 to 8 of 8
Thread: My AutoPilot has lost it's mind!!
    Round Rock, TX
    529
    I went and took at look at my AutoPilot control box today and it is way messed up.
    It appears to be speaking German, the cell is set to SC = 392, and it is in "shock" mode. If I hit the boost button it says "super shock".
    I tried to go into the install menu to reconfigure, but could not read anything it said.
    Is there a way to reset this thing, as I don't want to learn German or whatever language it is speaking now.
    thanks,
    David
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Round Rock, TX
    529
    Re: My AutoPilot has lost it's mind!!
    I did power cycle it, but that did not help.
    thanks,
    Jul 2007
    Brisbane, Australia
    874
    Well i could translate messages to English for you if that's any help, otherwise you would have to wait for Poolsean
    Ft Lauderdale, Florida
    1,455
    Power surge or lightning strikes lately? For whatever reason, it seems as though it jumped to a different language.
    Press MENU...it goes to TEST POOL PILOT.
    Press the UP arrow button. That should take it to OWNER OPTIONS.
    Press SELECT, this should take you to SELECT LANGUAGE.
    Press SELECT, then arrow UP or DOWN until you see ENGLISH.
    Press SELECT.
    Let it default back to the normal display. It SHOULD be back to English.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Round Rock, TX
    529
    OK I tried this and here is what I see.
    As soon as I press MENU I see EXTERNAL TIMER on the top line of the display. Others are on the second line
    Press MENU ... it went to TEST POOL PILOT
    Press UP ... See Choix Fonction
    Press UP ... See Eignes Menu
    Press UP ... See Wartungsmenu
    Press UP ... back to TEST POOL PILOT
    um, where now?
    thanks,
    tootie's Avatar
    Apr 2008
    NC
    46
    Quote Originally Posted by lovingHDTV
    = Choix, never knew this is a german word, sounds more like french..
    Owners Option
    Servicing Option
    um, where now?
    thanks,
    I don't know if that's of any help, but sure hope you can figure it out soon..I cross my fingers
    Margit
    24' x52" Intex metal frame
    Pentair sand dollar SD60
    Original pump 2500gph
    "5 years of BBB, and loving it"
    Round Rock, TX
    529
    I called Tech Support and they tried walking me through changing the language, but it appears to be more broken than that. They are sending a tech out to fix it. Luckily it is still under warranty.
