I have an IG 18000gal pool with 2 return lines in the pool and one return that I assume was built for a slide. That return was a capped pipe with a threaded cap, which extended 1' above the concrete, that I used to blow out the lines when I close the pool. I came home to some storm damage yesterday. Apparently, the solar cover reel was blown into the pool, hitting this return pipe and breaking it off at the concrete level (see pics attached).
I'd love to just cap the thing off and level it below the concrete, but I won't be able to blow out that line. It looks like there was a pipe extension put into it of some sort. The current ID is 1.25". No standard PVC has a 1.25" OD. Does anybody have any suggestions? The almost clear pool is turning green with each passing hour...
Thanks!
Thanks!
