rezasaba said:
frustratedpoolmom said:
Yes, what Joyce said. Test for FC and CC and then add bleach if needed, your other numbers are fine for now :-D (this is a good thing!)....
hi again here my new #s from Fridau morning at 7:00 am
test kit TF100
FC=10 , CC=0.5 , TC =10.5 , PH=7.4 , TA=140 , CYA= 58
I added 3 gallons of bleach to bring it up to 20 ppm then brushed it again . color of water is better Clearer then yesterday ,I think I am 95% there , the only thing is
CYA test eats up alot of the reagent there are 2 bottles in the kit I already used half a bottle !!!!
I also added some more water to the pool maybe 300 to 400 gallons , I fig. i need to lower the TA and also lower the CYA I think they should give a bit more reagent for the CYA test. as I brushed i still see some algee film in the pool . Pump is running 24/7 . I need to get a cleaner robaotic one i hope i get some feedbacks about it , i only got two responds to my earlier threat . I was on google looking at lots of them and i am now confused.
Your CYA is fine, it's on the high side, but
don't bother testing it for awhile. IT's not something that needs testing very often, unless you are adjusting it.
Adding water to your pool doesn't change the cya, really, replacing water does. So when you say you added it,
did you drain some first?
You raised chlorine to 20 which is good, when did you test for that 20ppm?
Was that a "target" or a "test result"? The reason I ask if you tested and got 20ppm, say last night, and then this morning it was at 10, with a CC of .5 and you still see algae, then you still have algae present consuming your chlorine rather rapidly. If this is the case then you need to
raise that chlorine back to 20-23 and
TEST to make
sure you reached that target, cause if you came up short with the bleach, you need to add MORE. Does that make sense?
You have to test to Know you reached your shock level.
Your TA is fine for now, don't worry about that, you can always lower it later unless it gives you problems like PH drifting up. Your numbers (except chlorine) look good!
Okay I hope this all makes sense, feel free to post questions if you aren't sure about what I said. :-D
