OK, so let me tell you what my findings are and what I think.. you guys can correct me if you need to.
you saw all the info above, I apologize, I was doing most of that stuff while I was working... so each time I get a break I would run over and do some testing... sometimes rushed.
So short story... as short as I can make it.
my meter with no contact reads OFL - same as if I am testing a circuit with nothing connected or an open wire. when I tested the run from the wall to the junction box it was disconnected and gave me no continuity or resistance... so other than the shielding it was OK. When I tested the rest of the wire (the line of lights) I got a 7-8 M ohm reading on white, and OFL on the black... it was due to no bulb... I put one bulb in at a time watching the meter and it was the same reading all the way to the last bulb 7-8 M Ohms... so at that point I could see that both lines were same as far as resistance goes, I found the ground wire for the first fixture (it was hanging on by one strand) I replaced it while I was in there. Next... I connected the ground/Black/White back (the wire that runs to the junction box - from the wall) and went back to test... it now reads a consistent 7-8 (did spike up to 9 a few times) but 7-8 was average. this reading was both wires... should I assume that broken ground in the first fixture was the problem? I am not going to put it back together for a week. we have rain coming tomorrow and that will be a great chance to check the wire agn (encase water is part of the problem). after a few days if the two wires show a consistent 7-8 M ohms and my pool light hasn't tripped the breaker (still hasn't caused any trouble) I will add the wall lights back to the circuit and hope for the best...
please let me know your thoughts...
if this works out, I am pulling the fixtures and replacing the ground on them all...
