Hello Everyone,
Here is my dilemma, and there is a long story leading up to why it is like it is, but I won't bore you all with the details.
I have an 18x33 oval above ground pool. At the skimmer end it is about six to eight inches higher (read lower water level) than the other end. Near the skimmer the liner has pulled out of the track, as well as a section down towards the other end.
I have been trying to somehow patch this to get through the season instead of buying a new liner now and making the job be done right. The long story is that the installation was never done right in the first place, last year, and now this year is even worse. I hate the idea of draining the pool to fix the liner and then filling again, and maybe winding up with the same problem.
So, if I don't keep filling the pool, it drains out where the liner is pulled out. I have to keep filling as much as I can because it is low enough to effect the filter and pump.
I have some very sticky roofing material and some "underwater tape" (lol) stuck all over it in an attempt to just be able to fill the pool. Of course none of this stays stuck for long and it begins to drain.
Is there any way to "patch" around where the liner is pulled out ... just enough to get through this season? Anyone have any genius ideas?
