Why are you opening already if you're in MD?
Gumby, I'm with you...cant stand looking at the pool cover but wifey keeps me in check and wont let me open till first week of May.
Are you closing following our methods when the water is below 60 degrees? I have no experience with this, but I do think it is harder to keep a clear pool with a mesh cover.
Would be hard to do that since the cover is tight and buckled down to the anchors and plugs are in all the discharge jets. Not sure I could loosen the sides of the cover and remove the plugs. But it does make sense and I imagine would make the opening a little easier.Even if you leave the cover on, it's good idea to get the water moving and adjust your levels.
I dare you to swim in it.
