Water_man said:
From the previous post I understand that you used TA =100 for the SI calculation.
What value did you use for CH? Suppose you reduce it by two increments of 50, what do you get for SI?
I used a TA of 100 and a CH of 300 for my calculations (also a temperature of 80F which doesn't matter much and a CYA of 30 ppm which does matter -- higher CYA has a larger pH rise). The CH does not affect the pH or the buffering so changes in CH are directly reflected in the SI index. The following table shows the relative change in the SI index as CH is lowered and this applies equally to the cases with and without Borates:
300 ppm CH --> SI 0 (relative starting point)
250 ppm CH --> SI -0.07
200 ppm CH --> SI -0.16
150 ppm CH --> SI -0.28
100 ppm CH --> SI -0.45
70 ppm CH --> SI -0.60
50 ppm CH --> SI -0.74
In
this post there was little white stuff at a CH of 70 while at 150 it was showing up a lot. This is all pretty consistent with the SI prediction if one assumes that one gets into trouble when the predicted SI gets to around +0.7 or thereabouts. It does seem to me that the use of Borates plus some minor adjustment of pH, TA or CH for a somewhat negative SI (-0.2 or -0.3) and having a lower CYA level would eliminate this problem for plaster pools (for vinyl pools, a low CH below 100 ppm may be enough), but we'll see.
Interestingly, a higher CYA level has the pH rise more in spite of the greater pH buffering. This is because CYA is a chlorine (hypochlorous acid) buffer so when you add more chlorine to the water that has CYA in it, the CYA resists this change and compensates by raising the pH (basically, more of the hypochlorous acid is removed by getting bound to CYA so reducing the amount of acid in the water has the pH rise).
So if we compare the situation at 30 ppm CYA vs. 80 ppm CYA we have the following where I used 116 ppm TA at 80 ppm CYA to have equivalent carbonate alkalinity (so same rate of outgassing and same initial SI).
NO BORATES, 30 ppm CYA, 100 ppm TA
200 ppm FC --> pH 9.01 --> SI +1.39
100 ppm FC --> pH 8.88 --> SI +1.30
80 ppm FC --> pH 8.83 --> SI +1.27
40 ppm FC --> pH 8.67 --> SI +1.13
20 ppm FC --> pH 8.41 --> SI +0.90
50 ppm BORATES, 30 ppm CYA, 100 ppm TA
200 ppm FC --> pH 8.34 --> SI +0.83
100 ppm FC --> pH 8.23 --> SI +0.71
80 ppm FC --> pH 8.19 --> SI +0.69
40 ppm FC --> pH 8.06 --> SI +0.57
20 ppm FC --> pH 7.89 --> SI +0.39
NO BORATES, 80 ppm CYA, 116 ppm TA
200 ppm FC --> pH 9.35 --> SI +1.64
100 ppm FC --> pH 9.19 --> SI +1.55
80 ppm FC --> pH 9.13 --> SI +1.51
40 ppm FC --> pH 8.85 --> SI +1.29
20 ppm FC --> pH 8.36 --> SI +0.85
50 ppm BORATES, 80 ppm CYA, 116 ppm TA
200 ppm FC --> pH 8.58 --> SI +1.05
100 ppm FC --> pH 8.46 --> SI +0.95
80 ppm FC --> pH 8.40 --> SI +0.87
40 ppm FC --> pH 8.14 --> SI +0.62
20 ppm FC --> pH 7.86 --> SI +0.34
So you can see that the higher CYA is particularly bad if the chlorine level, and hence pH, is very high.
Richard
