The SI45s we have are rated to put 2 lbs /day an up toft 45k gallons. My pool is 24k and I believe timerguys is also but I don't want to put words in his mouth
Sent from my SAMSUNG-SGH-I537 using Tapatalk
You know, I've not seen what the 2lbs /day means.
I FINALLY got mine installed and running. Shows my salinity level is 3500ppm after 16 bags. Everything working ok -- except for two minor leaks in a couple of my plumbing connections.
Initial numbers at start up:
FC-- 5.5
Cc--< .5
PH--7.8
TA--70
CH--90
CYA--60
Salinity--3400
Water temp--60
I'll run FC tests daily until I see how it's doing -- going to run it at 80% for 8hrs/day and adjust ss needed. We're going on vacation next Saturday week and I'd like to get it stabilized before we leave.
