Good afternoon! Our system froze during the sub-freezing temps and now our pump isn't working. There was frozen water in pipes/filter and a thin sheet on top of the actual pool. I had set the motor to start whenever temps dropped below 40, but it must have failed somehow.
Now everything is thawed out but when i turn the pump on it sounds like it's on but no water flowing through filters or anything at all.
I am admittedly very inexperienced with the pool but have only had to do routine maintenance up till now.
Thanks!!!
Thanks!!!
