My CYA is 120 and FC is 20-30 (retesting tomorrow). My ph on meter shows 7.0 (but may be calibrated wrong) and on tf100 test shows about 7.5. Assuming that high FC can cause ph to read higher than it is, do you think I should add some Borax to raise ph 0.3 to be safe?
I know I really should fire my pool company and take over, do the drain, and start fully balancing but I’ve been little hesitant to pull the trigger immediately since I’m still learning everything.
Figure in the meantime I should balance what I can until I take over fully.
