Results 1 to 11 of 11
Thread: Any way to get bigger vacuum hole?
    My AGP has an awfully small vacuum adapter hole below the in-wall skimmer. Then, it gets even smaller when INSERT the hose into it. It's causing my pump basket to drop water level, either through leaks or through "cavitation". That doesn't happen during normal skimming operation. So, that suggests I'd get better results with a larger hole below the in-wall skimmer.
    Anyone know of a way to do that?
    My skimmer is an older deluxe Doughboy.
    -Xebec
    Doughboy 13K Oval Gallon AGP. 1HP pump. Zeobrite filter.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Any way to get bigger vacuum hole?
    Can you find a vacuum plate to fit your skimmer basket? Mine goes on top of the basket and has a 90° elbow joint to which the vacuum hose connects.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    That's an interesting idea. The only skimmer plates I've found, so far, are simple lids that seal the skimmer so the water all comes in through the small vacuum hole in the wall.
    Any idea where to look for something like that?
    -Xebec
    Gulfport Mississippi
    54
    Most pool supply stores should carry them. I use one it works great.
    Here is a link to one for less than $12.00.
    http://www.a2zpoolsupply.com/more/57565 ... er-Marker/
    10,000 Gal. - Plaster – I.G. - Sand Filter – NOT USING MY Auto Puck Chlorinator.
    Oh, I've seen THOSE. Unfortunately, my doughboy skimmer is rectanglular.
    -Xebec
    54
    Oh, That is something I didnt know.
    Is your basket round?
    Some of the ones I just looked at on line are and that is the seat location for the adaptor.
    The basket is round, but it sits in a rectangular skimmer, which has a rectangular lid.
    -Xebec
    Mar 2007
    Coastalish 'down easter'
    4,160
    What you want is a skimmer vacuum plate that will seal over the skimmer basket. You can either measure the outside edge of the skimmer basket or just bring it with you when you shop for one
    Luv& Luk
    -Ted
    Yeah, I've been doing that, but I can't find one that fits the rectangle doughboy skimmer. I've only found round ones.
    -Xebec
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Since you mentioned that your pump sucks air when you vacuum, does the skimmer empty of water when you connect the vacuum hose? If it does, then you may be sucking in air from the skimmer.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Here's the result of my testing, so far...
    My hose from the skimmer to the pump has several joints (don't ask!), so I bought some putty that hardens like steel and sealed all those seams. Then, I ran the pump with the skimmer lid on and vacuum hose attached. I rubbed shaving cream over all the seams and confirmed (as best I can) that no air is getting in from the skimmer to the pump.
    Then, I watched the pump basket for about 10 minutes. Definitely less air in there than before, so I conclude there WERE leaks, previously, in my hose from the skimmer to the pump.
    Then, I watched the skimmer basket. As time went on, the water level slowly dropped, leaving more and more air in the skimmer. The skimmer lid (which is only kept on by suction) was letting SOMETHING through the edges, and it looked like air might have been mixed in with the stream. But, it was fully covered with water, and there was no "whirlpool", so I don't know if there really was air, or if there was, where it was coming from (maybe extracted from the water, itself?).
    Anyway, I've given up on the whole vacuum thing. My pool was badly designed with such small holes. I think the problems began when I replaced my pump. I must have replaced it with a more powerful one, and the higher suction is causing too much vacuum when sucking through that small hole.
    Instead of vacuuming (and instead of the aquabug auto vacuum), I'm going to get an Aquabot Rover Jr. It has it's own filter system, so I don't need to use the vacuum part of my pool.
    -Xebec
