Hi all...let's get right to it I guess!
Woke up this morning and the display on my Compool control system (pool/spa) CP3800 was showing the error code ERR1.
The manual says the following about this error code:
My pool has been closed since the end of October. Last night was the coldest night of the year with temps almost in single digits F.
My question is, do I need to be concerned about this until the spring? Does this indicate a possible problem with the winterization? Anybody else with this equipment experience this problem?
Any experience or advice is appreciated! I hate to stare at this error code all winter....it's an OCD nightmare!
If there is a fault with the Water Temperature Sensor, the display will show “Err 1”.
Check sensor cable and connections.
Replace Water Temperature Sensor (model TS-5L).
