Re: Liquidator removal help
Update.
I removed all the supplied valves and also the flow meter. I replaced the supplied flow control valve with a larger diameter flow control valve. I added 5 gallons of 12% to the LQ. My FC held after 24 hrs. This was an overcast 24hrs with a lower bathing load though. (My typical consumption to maintain FC is 3 gallons of 6% every other day.)
Usually we have all day direct sunlight and a very large bather load. Today has been hot and sunny with a normal bather load. If my FC holds tonight then I think its going to be alright. If not then I plan to remove my LQ and return to directly adding Chlorine to the pool every other day like I used to do. It worked quite well. I use my tablet chloinator when out of town.
I will let you know.
Update.
