Thread: cleaning SWG cell
    Jun 2008
    Savannah, GA
    17
    cleaning SWG cell
    I have a Goldline unit. It is connected into the piping with a pair of threaded collars, one on each end of the cell. You are supposed to imerse the cell in mild acid solution up to, bot not over the wires.
    Has anyone found a "trick" to do this easily. A container that fits well?
    I wonder why they don't sell a cap that would thread onto one end and let you pour the solution into the cell.
    18,000 gal IG plaster Hayward S244T sand filter Pentair Challenger Pump CHII-N1-1FE
    Goldline SWG
    Polaris 280
    Guest
    Re: cleaning SWG cell
    Quote Originally Posted by BobF
    They do but it's a bit expensive. They call it a "cleaning stand". I just use a small plastic pail.
    Mar 2007
    Coastalish 'down easter'
    4,160
    The other option, which I use, is to put a #11 expandable rubber plug into one end and pour the acid solution into the cell and let it soak for a few minutes.
    Luv& Luk
    -Ted
