Thread: Opening with high ph anyone?
    mbar's Avatar
    Ashland PA
    257
    There have been a lot of posts in the stain section on the Pool Forum this year about plaster pools getting scale over the winter . It seems that some dirt has gotten encapsulated by the scale, causing stains. Some of the pools are new, and others have not had a problem before with this. They all have mesh covers. I live in Northeast Pa and have a fiberglass pool - I have always opened to very low ph in the spring - this year my ph was above 8. I though it strange at the time, but chalked it up to the fact that my pool was a pond - we had so much rain this year, and my pool actually overflowed and had to be drained down. Then all those hot days.... I wasn't sure where to post this, but was wondering if many others noticed a higher than usual ph on opening this year?
    16x33 fiberglass pool sand filter
    DaveNJ's Avatar
    Toms River, NJ
    520
    Funny you should mention it, yes mine was very high also. Did not cover it, and yes it was a pond complete with ducks.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    mbar's Avatar
    Ashland PA
    257
    hmmmm very interesting (while rubbing chin)
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    I live in Central PA and my ph was low but not as low as it was last year but my pool was covered until the 26th of may I was kind of happy it wasn't as low as it had been before (less borax) :P maybe there was something in the snow this past winter?
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    I had very high pH to start and NO CYA - usually I still have CYA and the pH is fine - vinyl lined pool.
    Also had a couple of ducks using it twice a day until about a week ago when I tied fishing line all around and over the pool.
    I am finding a boatload of bird **** on my solar cover daily, from these blackbirds that keep bombarding everything that does not look like grass (pool, concrete walkways, driveway) - stupid birds - for some reason, this year is really bad for them and I wouldn't be surprised if all their **** has a lot to do with all these chemical changes. I hear they "dispose" of their baby **** from the nests by way of mouth - usually over water.
