So we are brand new to putting pools together. We followed the dvd and stuff, leveled the ground, used a level to make sure it was exactly level all the way around, then we add water to the pool and about 80% of the pool has around 2 1/2 to 2 inches of water in it, but a small area on the one outer edge has no water at all, as though that part is on a small hill, even when the level says it's the same height as the rest of the ground.
The pool itself are always even anyway when water is added so it can't be that. Any idea what is going on? My guess was the area that has water's ground sunk in afterwords, though it's less than 3 inches of water, so I don't see how it'd sink in that much. Any help/advice?
P.S: We are trying to drain the water out, but both drain caps are higher than the water, and the pool is still too heavy to move overall, so best thing we could do is just lift 1 small side to dig the 1 area, not sure if it'd help though.
