Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: PH was WAY low, now WAY high
    Hello,
    yesterday when doing my water testing, my PH measured at 6.8. I had a tablet holder in the water for a few days to make sure the water held chlorine because of the increase in teampertaures until I was able to get more bleach. I took the tablet holder out yesterday.
    Last night I added about 75 OZ of Borax into the skimmer.
    Today, my measurements show PH to be 8.2!
    Could the tablets have made the PH go wacky? Should I add some acid to bring it down or wait a few days?
    The chlorine level is holding steady at about 3-4
    Thanks!
    14,000 Gal. IG Plaster
    Hayward S244T Sand Filter W/ 1 1/2 HP Pump
    Hayward Pool Vav Ultra
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Do you have a testing kit so you can post a full set of numbers?
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Borax raises PH. If your TA level is low enough that makes total sense.
    Yes, you should add acid to bring it down, but this time use quite a bit less than you think you need.
    We can give you a lot more help if you post a full set of water test results.
    Oh yes...sorry...I've just been using the everyday part of the kit because things have been going pretty well until this bump in the road
    FC=1
    CC=1
    CYA=60
    TA=200
    PH=8.2
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    You need acid to bring it down. Use the pool calculator to figure the correct amount Just be careful as you don't want your cya to creap up too much too fast.
    Quote Originally Posted by whoozer
    I did use the pool calculator to try to bring up my PH. but my measurements must be off somewhere...maybe in my gallon measurements.
    Whats strange though is that I always use the pool calculator to add bleach and it's always right on, so I just wonder if I messed something up someplace.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Sorry jlhaz..it's late and my thoughts are garbled I didn't mean to imply adding ma would affect your cya just saw it was 60 and I know how easy it can go up. Anyway...
    Based on 14k it says 25oz. of 31.45% of MA. I think I would only use 8-10 oz to start and retest. Maybe even less to be conservative. As it is easy to test ph.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by jlhaz
    FC=1
    CC=1
    CYA=60
    TA=200
    PH=8.2
    Hey J,
    Try adding half the amount of acid, retest in an hour, and adjust as needed.
    You know you gotta' shock that pool!
    I'd work on getting that TA down!
    You're done SLAMing when:
    No problem...
    thanks for the info!
    Quote Originally Posted by jjparrish
    FC=1
    CC=1
    CYA=60
    TA=200
    PH=8.2
    Hey J,
    Thanks for the info...
    Do these #'s show that I have to shock? I thought if the chlorine held overnight at a pretty consistent level then i'm ok. My water is as clear as it has ever been.
    I'll try to get to the store tomorrow for some MA
    Butterfly's Avatar
    South Carolina
    10,045
    FC=1
    CC=1
    CYA=60
    TA=200
    PH=8.2
    Hey J,
    Do these #'s show that I have to shock? Yes. 1 CC means you need to shock Also, FC dropping to 1 is too low. I thought if the chlorine held overnight at a pretty consistent level then i'm ok. My water is as clear as it has ever been.
    It won't be for long if you don't shock!
    Here are a couple stickies to read:
    "ABC's of Pool Water Chemistry" by duraleigh: http://www.troublefreepool.com/sticky.php?s=4953
    "BBB" or, "What are all these pool chemicals?" by Waterbear: http://www.troublefreepool.com/sticky.php?s=94
    OK thanks...I stocked up on bleach this weekend and will get some MA tomorrow. i'll let you now it goes
    You should shock because CC is above 0.5.
    You have high TA, not low TA as I guessed previously. With high TA levels the PH will tend to drift up on it's own any time there is aeration of the water, which can happen from a SWG, waterfall, fountain, kids splashing, rain, etc. You will need to add acid regularly to keep the PH in a reasonable range. Try to keep PH between 7.2 and 7.8.
    Experiment with the amount of acid you use till you find an amount that gives the desired result. Keep in mind that the amount of acid required will be lower when the TA is lower and that if you wait too long after adding acid before retesting the PH will have gone up from aeration and you won't be able to tell how much of the PH change was from the acid and how much was from high TA and aeration.
    Longer term you should lower your TA, see this sticky for directions on lowering TA.
    OK got it thanks...I'll use MA until this weekend when I'll have the time to dedicate to bringing the TA down using your method.
    I do have an aerator on the pool so that should help with the process. Unfortunately my returns don't have eyeballs on them
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: PH was WAY low, now WAY high
    With the measurement numbers you later posted (especially the TA of 200 ppm), adding only 75 ounces (about one box) of Borax to 14,000 gallons would only bring up the pH from 6.8 to 6.9. By any chance, when you measured the pH that was low at 6.8, did you take a water sample near the tablet holder? If the circulation was poor or the pump wasn't running, then the water around the tablet holder could have been quite a bit more acidic than that in the bulk pool water. Otherwise, I can't explain the dramatic difference. The high TA will lead to a rise in pH, but not by that much in one day.
    Richard
    Quote Originally Posted by chem geek
    Richard
    You know, I really don't remember if it was near the tablet holder or not...it could have been..I really don't remember though.
    So my plan is to buy some MA, lower the PH thaty way and then follow the TA sticky this weekend to bring the TA down.
    Oh yeah, 1 more thing...can I shock while doing all of this? or should I do them one at a time?
    Thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    You won't be able to accurately measure the pH if the chlorine level is high so you should not shock while lowering the TA. Do them one at a time.
    jlhaz, you mentioned earlier that you are using the "every day" part of the test kit. By any chance are you using the OTO test for chlorine and reporting the 1ppm as both FC and CC? OTO only tests for total chlorine.
    If this is the case run an FAS/DPD test to see if you truly have CC. No reason to shock if you don't need to, especially when you're trying to regulate PH like Richard mentioned.
    Also, if your CYA is 60, you need to maintain a lot higher FC than 1 ppm. Just checked, target FC for 60ppm CYA is 6.8. Have you seen the Chlorine/CYA chart in the sticky section of the chemistry 101 forum?
    Quote Originally Posted by Rangeball
    No, when I was asked for a full set of #'s I pulled out the rest of the kit and performed those tests. I saw the Chlorine/CYA sticky but didn't think I needed it because I was just using the Pool Calculator.
    So I should probably use the Chlorine/CYA chart to find out my desired chlorine level, then plug the numbers into the pool calculator to calculate the amount of bleach, etc I need?
  20. Back To Top    #20
