I'm hoping you can help me get a better idea of my true pH. I've always known it is very bad as far as pH goes, but I would like to figure just how low it is. I started with the pH test from the K-2006. The pH was a pale yellow color. It took about 17 drops of base demand to get to 7.0. Next I did the TA test. When I added the indicator it turned a sick reddish color. It took one drop to go full red, for a TA of 10ppm. Lastly I did a pH test from the HTH 6 way kit, and got a reading well below 6.8. It was so low, it actually looked more like a chlorine reading. Based on all that, does anyone have any idea what my pH might be? Thanks.
Sent from my iPhone using Tapatalk.
