- May 12, 2012
- 191
- Vinyl
- Pentair Intellichlor IC-60
I have a question regarding a check valve that was recently added to plumbing. Per Pentair recommendations, we had check valve installed between filter and IC40. It is a spring valve and installed vertically. I have noticed a reduced flow rate and wanted to confirm that this could be caused by check valve. I would think that debris wouldn't be a problem since it is downstream from filter so is it just the inherent nature of the valve?
