Thread: Quick question
    May 2008
    Southern Virginia
    10
    Quick question
    I am wondering if the water will turn clear even if I don't vacuum the bottom. I have been using a leaf rake to dredge the bottom and the net would be completely full of sludge at first but I don't really get much at all now. I tried vacuuming this morning but it plugged up the filter after about 4 minutes. I don't want to vacuum to waste as all the backwashing from the conversion to CL has flooded my yard and turned the area around the pool in to a mud pit and I think my neighbors yard may be starting to flood as well. I am just hoping the water will turn clear whether I vacuum the bottom or not so I can use the rake some more or the yard will dry up enough to vacuum to waste by then. Any thoughts on this would be greatly appreciated. Thanx in advance.
    24' Round AG 13,000 Gal
    Hayward Sand Filter
    Southern Virginia
    You don't have to get all the sludge out, but getting it out can significantly speed up your conversion. Chlorine will break it all down eventually. Anything you can physically remove means less chlorine to finish the conversion.
    May 2008
    Southern Virginia
    10
    That's good to know. Thank you very much.
    Hayward Sand Filter
    Southern Virginia
    May 2008
    Jackson, NJ
    38
    Re: Quick question
    Quote Originally Posted by Munch
    Be careful that you don't cut the liner!!
    19500gals 28' x 54" AGR vinyl
    3/4 hp Hayward Pro Series High Rate Sand Filter S210T
    3yrs old June 2008
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Quick question
    Quote Originally Posted by poolpsycho
    How's he going to cut the liner? The leaf rake he's referring to isn't a broom rake like what you'd rake your yard with - it's a specific type of net you use to get leaves out of the bottom of the pool.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
